Palpigrade Build Thread
8 Channel balanced to unbalanced output driver kit.
Link to Tradigrade Build thread
Notes and Errata
C2 & C3 are 39pF not 47pF. 39pF gives 200kHz flat bandwidth.
PCB size is 55.25mm (2.18") x 77.35mm (3.05") with 4 x PCB mounting holes 47mm (1.85") x 56.7mm (2.23")
Or PCB can be mounted on the 2 x DB25 mounting bolts.
