PCB Component Build maps
Display PCB
http://jlmaudio.com/builds/maps/VUPPM50 ... y_map.html
MAIN CPU PCB
http://jlmaudio.com/builds/maps/VUPPM500_map.html
500 EDGE PCB
http://jlmaudio.com/builds/maps/VUPPM50 ... nalog.html
500 EDGE PCB DIGITAL ADD ON OPTION (Build and test VUPPM500 as analog first then add on digital option)
http://jlmaudio.com/builds/maps/VUPPM50 ... gital.html
Test procedure Analog input
Plug in built VUPPM500 module.
Press Meter Mode and Peak Mode together to go into led test mode. This shows all green then all orange and then all red.
Press peak reset to set brightness level to LOW, MEDIUM, HIGH.
Press either Meter Mode and Peak Mode to leave led test mode.
Test procedure Digital input
Send in AES/EBU 1k tone at 0dFS into 500 Input.
