STATTEN Build Thread
Postby Joe Malone » Mon Sep 18, 2017 12:52 pm
Under Construction
STATTEN is a Stereo U or H attenuator for make passive mixer with volume and/or pan controls.
I will get some drawings up soon to explain this kit better but in the mean time feel free to ask any questions you have here.
Note1: Current Ver1 PCB mono jumpers for pull pot doesn't work. All other functions work fine.
kante1603
Re: STATTEN Build Thread
Postby kante1603 » Mon Sep 18, 2017 4:37 pm
Thank you Joe,
1.) Looking at the first pic,does that mean the STATTEN pcb takes ALPS RK27xxxxx series pots?
I have quite a few of them.
2.) So the "pan pcb" can be directly attached the "volume pcb",yes?
3.) Talking about pan,isn't this balance instead?
4.) When do we use u-pads,when h-pads ( having in mind the e.g. the AMPHEAD II already has 10k resistors on the inputs).
I'm sure once you have done the drawings it will get more clear to us.
Thanks in advance,
best regards,
Postby Joe Malone » Mon Sep 18, 2017 4:47 pm
kante1603 wrote:Thank you Joe,
Yes correct. The Amp Head II can as well but the front half of the RK27 will be off the front of the PCB on the AMP Head II and have to wire those 3 pins back to the PCB. STATTEN pcb takes RK27 6 legs directly on the PCB.
Only by ribbon cable. You can ribbon cable pan U to volume H and ribbon all the volume outputs together or Volume U to Pan H and ribbon all the pan outputs together
Yes correct. Pan is just shorter to write on the PCB.
Yes it is simple but powerful :-)
