Sorry, i'm confused about the regulator too..
So i'm using 9 relay boards hence 74 x 12VDC relays.
I'll use a 24VDC PSU.
So does the 7812 regulator will drop the voltage for the whole circuit or just for the ULN2803??
According to the schematic it does but what you said early in this thread has confused me..
I could just use a 12VDC supply and bridge the reg pcb pins but possibly the circuit would behave better with local regulation?
Paul
Is the 24v only for the relays? If so use either 24vdc relays or 12vdc power supply with 12vdc relaysmrclunk wrote: ↑Wed Jun 24, 2020 12:59 amSorry, i'm confused about the regulator too..
Paul
Or is the power running something else? Or a spare power rail you already have?
The reg is more for if you have a existing higher voltage rail and want to run lower voltage relays. But if power rail is only for the relays best to run the same volts as the relays to make it simple.
Thanks Joe,
successfully installed my box in studio yesterday.
After a few balanced to unbalanced wiring cock ups it works a treat!
I'd read the IDC connector pin out as 1 = Shield 2 =Hot 3 =Cold 3 etc.. But it's 1 = Shield 2=COLD 3=hot so the unbalanced console SND and RTNs didn't work..
Cool great to hear you got it all working. Be great to see a photo or two on here or facebook of the final buildmrclunk wrote: ↑Tue Jul 07, 2020 12:08 amThanks Joe,
From what I understand one can only use two relays via one switch at a time?
Please correct me if I am wrong.
So like a register of 3 inputs; 1 cancels out 2 and 3. 2 cancels 1 and 3 and so on?
Is there a way to make it so all can be on or off?
Thank you
Thank you
All 8 relays can be switched individually so just up to your switch wiring. But with some diodes this would be easy.Rocinante wrote: ↑Tue Nov 17, 2020 3:30 pmJoe,
Thank you
Relays are turned by applying 5v to 24v to the 1 to 8 pins in the 16 header.
So I was originally getting this kit in order to switch between two different sets of vactrols in a tube compressor I'm building.
Here's the schematic:
http://www.silentarts.de/DIY/D-AOC/D-AOC_Schematic.pdf
This is a high voltage tube project, and I am a little uncertain if I can use these relays to switch between two vactrols (or actually between two pairs of vactrols per channel, as I am running vactrols back to back for full wave rectification of the sidechain signal).
Would I need to just switch out the diode side of the vactrols, or the resistance side of them aswell? Are there high voltages being switched, and would these relays be suitable? This pcb might even be quite overkill, if only the diode side needs to be switched? I am also planning a simple signal router box that this kit would come handy in, so will be useful either way.
All the best,
Magnus
All the best,
Magnus
Yes a low volts relay can switch the opto leds or LDRs. To do full wave you will need the opto leds back to back unlike shown in the circuit. Put the Dual sets of back to back leds in series so a single SPDT contact on the relay or switch will short one set of back to back leds and open the other set I would also add a protection series resistor in series with both the leds. Or just switch 0v to either set of leds.fragletrollet wrote: ↑Mon Feb 08, 2021 2:38 amSo I was originally getting this kit in order to switch between two different sets of vactrols in a tube compressor I'm building.
All the best,
Magnus
