Talkback Comp Build Thread
mrclunk
Re: Talkback Comp Build Thread
Post by mrclunk »
I'm sorry Joe, i ment to update my post...
Mic worked fine using the standard (2 x 6k8) supply as on the pcb. It's an Astrada conference mic 952.353UK (just the gooseneck mic part)
All working nicely on our Calrec. I added a 1k Log pot across the output for volume and a cheap OEP a262a2e transformer to split the output.
One to the desk auxs and a separate out to patchbay for remote session down Skype etc.
mrclunk wrote:I'm sorry Joe, i ment to update my post...
Cool great to hear you got it all working :-)
mrclunk
Post by mrclunk »
I have a slight issue with the TB amp.
I'm getting a loud pop when turning the TB on and off.
Is there a way to eliminate this?
Could it be DC on the relay contacts?
mrclunk wrote:
Sat Aug 22, 2020 12:28 am
HI if built properly there should not be any dc on output. If getting pops make sure you are not sending phantom power into the output and there is no dc voltage leaking to the output xlr pin 2 & pin 3. Measuring with a meter from 0v to pin 2 and pin 3 will show if voltage is there or not. Try measuring with nothing plugged int the output first and then with it plugged in and let me know what find.
williard86
Post by williard86 »
Couple questions:
1) any recommendations for a substitute for the ever hard to find 2n5457?
2) how can I have an adjustable threshold control? Coarse adjustment would be fine.
3) for an external gain control, would I need a reverse log 10k pot?
williard86 wrote:
Mon Sep 20, 2021 2:55 am
Couple questions:
HI Sorry completely missed this post
2n5457 is not that hard to find and would be a lot of work to get another type of fet to work in there.
Adding zeners or diodes in series with the threshold wires with vary the threshold level
Yes use 10k rev log pot for external gain
