Passive Controller Build Thread Ver 1 - 3
Corpselectriques
Re: Passive Controller Build Thread Ver 1 & 2
Post by Corpselectriques »
I see you add a note : Note 4. Do not push rotary switches down to the pcb as they may short on solder joints under them.
I cut the pins under the Switch short, but yes, I pushed them.
Do you think that's the cause !
It be too hard/long and not equipped to unsolder all the Switch pin for move it. I'm kind of stuck ! :x
Maybe for a next batch, it be a good think to move them side of the rotary switch for avoid problem.
best
F
dneilsen
Post by dneilsen »
I have built the controller along with the tascam breakout pcb and I am not getting any sound out at all.
I suspect the issue lies in the ICB connections on the 26 wire ribbon cable and I am in the process of getting more connectors for this.
Can you please confirm that I have the dual 10k pot wired correctly?
dneilsen wrote:
Wed Jul 22, 2020 11:29 am
You need to add a link from the centre pin to the right pin on the front and back pot so the volume will work. At the moment the volume should be stuck on full.
