Taperocket
Post by Taperocket »
Not seeing any voltage across the LEDs. I took it apart today to look for shorts, measured the resistors which were fine, checked the header orientations and everything looked good so I’m at a loss. Pics attached. Thanks,
Taperocket wrote:
Thu Sep 09, 2021 11:01 am
BB3A1504-0337-4799-8D93-453BB1454A5B.jpeg2DFA11A2-CA26-415D-BFBD-861C1D05136D.jpegF4186741-32E5-496B-93E6-131AD42A9071.jpeg
Need to see a photo of the main pcb top and bottom in focus helps.
You are pulling the makeup and threshold pots outwards so they switch on the leds?
Taperocket
Yes. I will have to reopen tomorrow to take some additional pics, sorry about the focus issue on the last few.
Taperocket wrote:
Thu Sep 09, 2021 12:03 pm
The main thing to check if it is back together is that you have +/-15v to 16v on the 2 x 10R at the end of the LA500SC pcb.
Can you calibrate the comp ok? Like does the meter light in VU or GR mode?
Taperocket
Here are the pics of the main PCB that you requested, Joe. My phone camera seems to struggle with focus on the back of the boards - I hope this works.
I ordered a 500 series extension cable to assist with further testing because I can't access the board with my test probes as is. All other functionality seems normal - the unit calibrated fine and meter lights on both GR and VU modes and works as it should as does the compression/makeup gain.
Taperocket wrote:
Fri Sep 10, 2021 8:18 am
processed-d7efd685-c3fc-41ef-b961-22a541f32c8a_Opqt7d5Z.jpegprocessed-47950647-8c1c-4e53-abde-944b921d0683_NQOgSKEL.jpegprocessed-817d405f-acb8-43d1-bece-0f275a81264f_YQ3aaJ49.jpeg
Do the 2 LEDs test dead short?
Taperocket
No, checked for continuity between them and they did not short together.
Taperocket wrote:
Fri Sep 10, 2021 12:31 pm
Taperocket
Yes, I regularly keep the threshold pot pulled out for slower attack.
Taperocket wrote:
Sat Sep 11, 2021 4:45 am
If you remove the leds and have the pots pulled what voltage do you see across the led pads?
Taperocket
Looks like the issue resolved itself when I pulled the boards last time and reassembled. I'm guessing it's related to the ribbon cables somehow - either a loose connector on one of the headers or an intermittent lead. Either way, both LED'w are lighting now without any changes.🤔
