I have 4 Channels strip (preamp and EQ) coming from an old French mixer : "Plus 30". It's fed with one Power station (with 6 Amp bridge rectifier) +-18v for the OpAmps (2 x DA1034N and 8 x LF366) and +24v (for the relays)...
I now have 4 extras channels I want to put in the same rack, I also intend to power 8 regurgitator kits ; do you think the Powerstation is powerful enough for 8 channels and the kits ?
All the best
Kenan
Is one power station enough for 8 preamps ?
Re: Is one power station enough ?
Hi Guys,
I can't say that my post has been really popular but I need some help on this. Does anyone has an idea of the electric consumption of such channel strip ?
Eventually, I could generate the 24V with another power supply but I can't use V1 for four channels et V2 the others four because the connection is made thru a board (picture) with regulators.
Could it be a solution to set V1 and V2 on 18V and pair V1 and V2 to double the current and make 18V 3A and -18V 3A ? Thanks for your help.
