1272 to 1290 Module fit to Neve 1272
Posted: Mon Nov 10, 2014 4:31 pm
Link to how to fit 1272 to 1290 module to Neve 1272.
This works for all versions of the 1272 to 1290 kit as they all have the same colored wires.
http://www.jlmaudio.com/JLM%201272%20Switch%20Kit.htm
Re: 1272 to 1290 Module fit to Neve 1272
Posted: Sat Sep 09, 2017 11:57 pm
by api
Hi Joe.
I am about to install a pair of these modules into some vintage 1272´s.
The Neve modules were already a bit modified with another gainswitch plus a 31267 line input transformer.
I thought it would be cool to keep and integrate the 31267 transformer for a separate line in and wanted to have this at the lowest gainstep (15db) of your switch.
I have tried to trace your pcb but its kind of hard without removing all components, so wanted to ask if you maybe had a schematic of this module?
Or do you have any idea where to add the signal to the pcb and how to redirect the mic signal?
Dennis
Posted: Sun Sep 10, 2017 8:58 pm
api wrote:Hi Joe.
Dennis
The 1272 to 1290 module is the same as the first half of our 1290 module kit. You would have to cut track so 270 wasn't connected to the 330ohm switch contact but to 0v instead. Remove 330R and change 270 to 600ohm. But 10468 with input pad sounds so much better than 31267 that you would be better just using our go between kit to add a 48v, 20dB pad and phase for much better line input sound and save the 31267 for something else.
1290 kit schematic
https://www.jlmaudio.com/JLM%20Micro%20 ... rboard.pdf
1290 built thread
viewtopic.php?f=2&t=180
Posted: Fri Sep 15, 2017 7:39 pm
by api
Hi Joe.
Thanks for the info.
I just wanted to try something different, and the 31267 were already mounted inside the modules when i got them.
But got it all wired up now, added the resistors to the new "line input" on your module to simulate the unitygain step on the original switch.
So now everything works exactly like it should and it all sounds good.
But will most likely add your go-between anyway on a sidepanel as well.
Posted: Sat Sep 16, 2017 9:12 am
api wrote:Hi Joe.
Excellent. Great to hear to you got it all working. Yes Go Betwen kit gives you all the features the 1272 is missing to make it a real mic pre.
Posted: Tue Sep 26, 2017 2:05 am
by api
Hi again Joe.
Yes, will be a great box in the end.
I do have some criticism about the new pcb, it is to large to fit straight inside the 1272 if you choose to keep the inner frontpanel, it does not match up with the hole in the front if its straight.
You need to angle it on the switch axle, and if you angle it you have a problem with the high capacitor that sits next to the switch which does not realy fit, so i had to mount it on the backside of the pcb, flush with it to make it all fit.
It would have been easy to make the pcb 1mm shorter at that end so you could have the option to use the inner frontpanel if you want to (like me).
Posted: Tue Sep 26, 2017 9:59 am
api wrote:Hi again Joe.
Yes that is already on the revision list for the next pcb run.
We just use a metal nibbler or sidecutters to take one nibble out of the side of the pcb next to the cap to make this fit perfectly with support panel in as it is only ground plane in that corner.
Posted: Fri Sep 29, 2017 11:08 pm
by api
Ok, sounds good!
