500 series extender kit..
Posted: Tue Sep 23, 2014 10:57 am
by Mixmaster-Nate
Hey Joe...call me stupid, but this extender kit I've built doesn't appear to work for me. It powers up the modules but passes no signal. It appears to test ok with a multi meter. I haven't yet trimmed the 51x parts of the pcbs, however it still seats ok on each side. Any thoughts?? Errr...something so simple. Piccies attached. :? Thanks, Nathan
Re: 500 series extender kit..
Posted: Tue Sep 23, 2014 11:56 am
Mixmaster-Nate wrote:Hey Joe...call me stupid, but this extender kit I've built doesn't appear to work for me. It powers up the modules but passes no signal. It appears to test ok with a multi meter. I haven't yet trimmed the 51x parts of the pcbs, however it still seats ok on each side. Any thoughts?? Errr...something so simple. Piccies attached. :? Thanks, Nathan
HI Nate
Looks built ok but it should not seat properly in the connectors unless the 51X edge connector is cut off with cutters.
I cannot see the important side which is the soldering. You should be able to use a meter to check pin 1 is 0 ohms to socket 1 etc. The only one that should be open circuit is pin 3 as it is not used for anything. Also check there is no short between any pin to the pin next to it on each side.
What module are you using to test this with? Is it a normal 500 module or a kit you just built?
Posted: Wed Sep 24, 2014 12:48 pm
by Mixmaster-Nate
Bwaahaaa!! :twisted: :roll: :wink: :shock: :oops:
Got a short between pin 1 + 2 in one of the black ribbon cable plugs - see pic/bent pin. Only shorting when the cable is extended a certain way....ie; fitted to module/rack.
Was attempting to use it with a 500v and normal 500 modules i.e. JLMs, APIs, Harrisons etc....
Can I order a couple of spare plugs from you? Broke the plug during surgery. I'll trim the ribbon and re-connect. :lol:
Posted: Wed Sep 24, 2014 1:25 pm
Mixmaster-Nate wrote:Bwaahaaa!! :twisted: :roll: :wink: :shock: :oops:
Yes drop me an email with address and parts you need so I can cut and paste it to our shipping system and get it out today
