Page 6 of 7
Posted: Wed Feb 24, 2021 2:45 pm
by verticalmammal
Joe Malone wrote: ↑Wed Feb 24, 2021 1:29 pm
Voltages are correct. Have you retried the pcb since cleaning it? Also first turn the trimpot back 25 turns encase you have one on full gain. With no meters connected measure volts across +M- on both sides and let me know what volts you read?
Yes, unfortunately still no joy, same symptoms. Voltage is 0.002v across the left meter leads, and 6.22v across the right. Turning the pot has no effect. I'm not sure exactly how these pots work, do they have stops on either side of the range? I can spin mine more than 24 turns in either direction, maybe I broke the pot somehow during install or setup? Or maybe that's normal? If I go too far CW I hear a soft click once a rotation, I'm assuming that's the top of the range?
Posted: Wed Feb 24, 2021 2:54 pm
verticalmammal wrote: ↑Wed Feb 24, 2021 2:45 pm
OK the 10uF cap on that side should be blocking the dc so may have a solder short under it. Remove the 10uF and retest the +M- to check the DC is gone or not? With cap removed should be 6.2v on + side and 0v other - side of cap pads.
Posted: Wed Feb 24, 2021 3:21 pm
by verticalmammal
Joe Malone wrote: ↑Wed Feb 24, 2021 2:54 pm
Dude, you are a genius. I could see the solder bridge on the bottom when I removed it. Zipped it off with my iron and now we're right as rain. I'd like to make a small donation to the charity of your choice as a show of thanks, let me know who you'd like it to go to.
Posted: Mon Mar 01, 2021 9:37 am
verticalmammal wrote: ↑Wed Feb 24, 2021 3:21 pm
Cool great to hear that got it working
Charity link below thanks.
https://donateplanet.com/charities/read ... in-cancer/
Posted: Mon Mar 01, 2021 12:01 pm
by verticalmammal
Done and done. Super-impressed with how you honed right in on the issue with your troubleshooting steps. I had my suspicions about the caps on that side as I mentioned (although it was for the wrong reason), but even if I maybe could have found it on my own eventually, I definitely couldn't have figured it out anywhere near as fast as you did. Between that and the help you provided me with my order this donation is the least I can do. Thanks again.
Posted: Mon Mar 01, 2021 2:21 pm
verticalmammal wrote: ↑Mon Mar 01, 2021 12:01 pm
Cool
Posted: Fri Mar 12, 2021 11:36 am
by Cfeedback
Joe Malone wrote: ↑Wed Feb 24, 2021 7:34 am
Cfeedback wrote: ↑Wed Feb 24, 2021 3:38 am
Great, that was the solution.
I connected -DC of VU2 with PGND of the output stages and now everything is wonderful.
Thanks again for your help...
Cool great to hear that fixed it. When you have 2 power supplies like this you have to reference them to each other.
Yes, you're right, I would never have stumbled over it so quickly.
I will remember in any case if I should have such a problem again.
The subject of ground loops is sometimes really complex, I think.
PS: The JLM AUDIO website/shop/forum is really first class, and very interesting.
And your know-how is remarkable.
Many Thanks and stay healthy
Posted: Fri Apr 09, 2021 7:59 am
by mobtownstudios
Hi all!
The VU build was fun and relatively easy!
I have not been able to get the LEDs to light up. There is voltage headed there which I am metering at 11.57v on each LED tap.
Any idea why they are not lighting up?
The VU meters themselves are working wonderfully, however.
Thanks!!
Posted: Fri Apr 09, 2021 9:19 am
Hi Mat RLamp for the 5v led backlight is 680R. You have fitted the 10R option for meters with lamp backlight. Meter backlights should have been very bright for a second or two before burning out. If not hopefully you have the lamp wires reversed. Change to 680R first before reversing if that is the problem.
Posted: Fri Apr 09, 2021 9:20 am
by mobtownstudios
Update:
Looks like I miss this instruction.
The 2 x RLAMP resistors = 680R for new 5v LED Lamp meters and 8 x diodes are NOT fitted just 4 wire links as shown.
So I fixed that, but the voltage on the LEDs still clocks in at 11.57v.
Are my LEDs blown? Or just not getting the right voltage?
Posted: Fri Apr 09, 2021 9:23 am
Hi Mat posted at the same time as you see above post.
Posted: Fri Apr 09, 2021 9:27 am
by mobtownstudios
Thanks Joe for replying!
Yeah, no luck there with the new resistors and diode removal with the 4 jumpers. I tried a continuity tester with the LEDs and they appear to be blown.
Would these be good replacements LEDs?
https://www.amazon.com/Adafruit-Accesso ... B00XW2MY84
All this soldering is fun! Wish I had more kits to build!
Is that voltage of 11.5v correct?
Posted: Fri Apr 09, 2021 9:36 am
Posted: Fri Apr 09, 2021 9:47 am
by mobtownstudios
Yes. Very bright then turned/blew out.
I measured 12v at the led terminals. Is that acceptable?
Posted: Mon Apr 12, 2021 5:59 am
by mobtownstudios
Joe Malone wrote: ↑Fri Apr 09, 2021 9:36 am
Thanks Joe!
