mobtownstudios wrote:
Mon Apr 12, 2021 5:59 am
Fri Apr 09, 2021 9:36 am
Thanks Joe!
Either make RLamp resistor larger in value to dim or add a resistor in series with one of the meter wires on each meter.
Going to 1 led will make it brighter and unbalance the backlight to one side.
mobtownstudios
Post by mobtownstudios »
Perfect!
I put the 3k3 resistor in place of the 680 and it's working WAY better for me!
Thanks Joe!
Tue Apr 13, 2021 12:03 am
Perfect!
Thanks Joe!
Cool. Must be very high Mcd LED like 10000. More efficient less power needed :-)
