Supablake wrote:
Wed May 26, 2021 5:55 am
I’ve just finished the assembly of the VU2 kit,
Meter lights work, meters move very slightly on turn on,
But,
No response to input signal.
I’m using balanced inputs driven for testing with a Neutrik Minirator.
+4 DB gives nothing, I’ve adjusted the trim pots and still nothing.
Any suggestions on where to start trouble shooting?
Also what sort of voltage would I expect to measure from the meter outputs ?
Blake
What meters are you using with the VU2 kit?
Do you have diodes fitted to the VU2 or not?
Send me some photos of the VU2 top and bottom and wiring to the meters and 12v power to check for you.
Supablake
Post by Supablake »
Not sure of the Meter Brand. eBay from China.
I have not added any diodes to the meter or between the meter and the VU2.
The meters have functioned with a couple of other brands of driver board,
But the Boards were unbalanced and introduced hum into the system.
The VU2 is powered from a regulated 12v board,
The lamps in the meters light up fine with the bypass resistor. They came supplied with their own to put in parallel with the meter lights.
I have several other meters I’ll try out.
Supablake
Post by Supablake »
Please disregard my posts.
User error.
I hadn’t adjusted the pots far enough.
I put a multimeter set to Mv and quickly saw that I just needed to keep turning the pots to get the readings I was looking for.
Thanks again!
Supablake wrote:
Thu May 27, 2021 7:42 am
User error.
Thanks again!
Cool great to hear you got it working. Yes the 25 turn trim pots need lots of turns as they control a large gain range so it will work in any setup.
kmf123kmf
Post by kmf123kmf »
Just got mine assembled and am having an issue. Possible user error as I didn't notice that R2R and R2L weren't installed before powering up. Both meter outputs showed around 0.2 DC volts regardless of input. Once I did notice the missing resistors and installed them, not much changed. Meter output voltage dropped in half is still basically invariable to input. I'm pretty sure I've turned the POTs enough and even tried replacing R7 with a lower value.
Did I damage the opamp or is there some other basic debug I should start with?
kmf123kmf wrote:
Wed Nov 24, 2021 1:06 am
The buffer outputs have a cap so no dc can make it to the meter. Leaving those resistors out will not damage anything. Best first to send me some photos of the wiring and setup you have so I can see if I can spot the problem. Otherwise, as always top and bottom photos of the pcb helps to check for problems as well.
kmf123kmf
Post by kmf123kmf »
Wed Nov 24, 2021 9:34 am
Top Side. Not using lamp power, so no RLAMP resistors.
Bottom Side
XLR's tied together on PCB. (Blue goes to red, white to white, sleeve to sleeve)
Input end. Looks messy, but verified conductors are not shorted.
Feeding -12/+12 from the aux of my SMPS
kmf123kmf wrote:
Wed Nov 24, 2021 1:45 pm
Looks fine. Not sure if that 24v is tied to the same 0v as the power amp voltage. You should be able to measure the ohms across the gain pot on the buffer with the buffer off. Takes 25 full turns end to end.
What meters are you running as they may have an internal resistor and/or diode bridge?
kmf123kmf
Post by kmf123kmf »
Thu Nov 25, 2021 2:27 pm
I measured the pots and they are fully open, close to 0 ohms. I'm using some eBay Chinese 34mm round vu meters. I'm pretty sure these are all functionally the same?
I checked the other components on the board and they all seem to measure fine.
Please forgive my limited electronics knowledge, but at suggestion of Google I put the TL072 on a breadboard and put it in voltage follower mode. With VCC+ 12v and VCC- to ground I'm getting +12v output whether the non-inverting input is either 12v or ground. Is that the expected behavior? Is behaves the same on both sides of the IC.
kmf123kmf wrote:
Sat Nov 27, 2021 2:12 am
The VU buffer pcb makes a half voltage rail reference for the TL072. So all the pins of the TL072 except pin 4 = 0v and pin 8 = V
So your setup measured from 0v on the buffer pcb pin 1,2,3,5,6,7 = 12v and pin 4 = 0v and pin 8 = 24v. Let me know if the voltages are correct on all pins of the TL072
kmf123kmf
Post by kmf123kmf »
Mon Nov 29, 2021 10:10 am
Pins 1, 4, 7, 8 look correct. 3,5 are low and 2,6 are high
pin 1 = 12.4v
pin 2 = 17v
pin 3 = 9.6v
pin 4 = 0v
pin 5 = 9.7v
pin 6 = 17.2v
pin 7 = 12.7v
pin 8 = 23.8v
kmf123kmf wrote:
Mon Nov 29, 2021 1:26 pm
pin 1 = 12.4v
pin 2 = 17v
pin 3 = 9.6v
pin 4 = 0v
pin 5 = 9.7v
pin 6 = 17.2v
pin 7 = 12.7v
pin 8 = 23.8v
The opamp and power are working fine as pin 1 and pin 7 outputs are still at 12v. The rest are a bit out because you have the gain fully cranked which for a XLR input should be way too much gain. Something is wrong with the input or the meter wiring. You do have the meter going to +M-? and remember if they are reversed the meter it will push downwards which you can be hard to see as it will not move far. I would wire the meter directly to the input XLRs without the amps and see if you can get the meters working on their own without the amp input attached.
