JLM 60Watt Power AMP Kit
greenmanhumming
Re: JLM 60Watt Power AMP Kit
Postby greenmanhumming » Mon Aug 23, 2010 8:58 pm
OK, thanks, I figured the AMP wouldn't be loading it much.
I've used a separate 48v supply as I want to keep the phantom to spec.
flaheu
Postby flaheu » Thu Nov 10, 2011 6:50 pm
HI folks,
I've just bought 4 amp kits for my Rhodes super sattelite rig.
The goal is to replace the internel amp of the 2 speaker boxes.
The original amps are rated at 100W rms each, which I doubt.
So, I think I'm going to make a bidged 120W per speaker.
But I have no idea how to connect them in bridge mode at the speaker output and at the input.
Do I have to connect the input in parallel ?
What about the volume control ? double gang 10K pot ?
The signal going to the jlm bridged module will be unbalanced (coming from the Rhodes on board preamp), how to connect them ?
Recommended TX for bridged config is 2x 18V, but is 160VA tx optimum ?
Thanks in advance.
Postby Joe Malone » Thu Nov 10, 2011 8:29 pm
160VA 2 x 18vac will work perfect for one 120w bridge amp but use 300VA 2 x 18vac for two 120w bridge amps.
Coming Soon 8 channel amp on 184mm x 82mm PCB that I just designed for Dolby Labs.
flaheu
Postby flaheu » Thu Nov 10, 2011 10:57 pm
Hi Folks,
Thanks Joe, you rule :) best world class service !!!!
is the pix below ok for my unbalanced bridged volume controled 120W amp 8)
-I suppose that the output must be isolated from the chassis
-for the mute switch a DPDT is necessary ?, contact closed muted, or the other way around ?
possible to get the schematics, i'm not the best to redraw from pcb :oops:
Thanks, I'm going to post photos when everything's done.
Postby Joe Malone » Thu Nov 10, 2011 11:21 pm
Your drawing is correct. Just wire both mute terminals together and switch to a -v for sound. If mute not needed just wire mute terminal permanently to -v.
wizardofoz
Postby wizardofoz » Fri Feb 03, 2012 1:42 am
The new boards arrived today and as luck would have it all was ready to roll within an hour or so as the rest of the build was all done and dusted....
Here is the final result
Nice one Joe...little gems you have there...and now they are mine too :D
Postby Joe Malone » Sat Feb 04, 2012 9:12 am
They are a great looking set of mono block amps with very neat layout. Excellent build :-)
Only thing is there should be a earth/ground wire from the IEC block ground terminal to chassis to make the chassis 100% safe.
Or does that filter IEC have the metal shield come around to under the 2 mounting bolts go it is already connected to chassis?
wizardofoz
Postby wizardofoz » Wed Feb 08, 2012 2:26 am
The shield is grounded at the screws and wraps the IEC and filter/fuses (2) completely, with the earth tab passing through the shield too. I metered it out and its all good.
Client very happy... Replacing a Bryston 2b lp pro with a horrortone monitor :P Plus a new setup in another studio.
Now I just want that 8 Channel board for my home setups. This could be a great amp for the Linkwitz Orions!
wizardofoz
Postby wizardofoz » Sat Feb 25, 2012 4:50 am
How is that 8 Channel board coming along Joe?
Any more details like ps requirements and the like?
slb1959
Postby slb1959 » Wed Mar 07, 2012 1:03 am
Hi,..
Few weeks ago i repair a Active Speaker from a friend. The amp is a 3xlm3886. Two for the woofers and one for the tweeter. I like to make one pair or two for me. I gone by some of your pcb´s, but the shipping cost,.. :(
Ok,.. I work in events with sound. I normaly connect pc´s "laptops" to active speakers.
I made a draw based on your pcb. Can you help to correct me to i can made a good amp.
Sorry,.. my English.
Thanks, Luis from Portugal
ps - congratulations for your kits. "and one usb dac to xlr stereo output?"
Postby Joe Malone » Wed Mar 07, 2012 6:11 pm
slb1959 wrote:Hi,..
No sure what you mean about shipping cost as it should only be about $10 or so to ship several PCB's if you read on the web shop how to do the PCB discount code.
Drawing is to small for me to read. Post a larger copy so I can see it :-)
slb1959
Postby slb1959 » Wed Mar 07, 2012 10:05 pm
Hi,...
I hope that picture are with better resoluition.
Can i pay with Paypal?
Thanks, Luis
Postby Joe Malone » Thu Mar 08, 2012 8:49 pm
slb1959 wrote:Hi,...
I hope that picture are with better resolution.
OK looks right. But are you using the same box and woofers and tweeter as described a few pages back on this thread as this will only work for that exact configuration. Volume control can be done with normal dual 1k to 10k log pot. I can draw how to do this and send with the order.
Yes JLM Audio web shop excepts Paypal.
slb1959
Postby slb1959 » Fri Mar 09, 2012 12:04 am
Hi,..
"Yes JLM Audio web shop excepts Paypal"
Aceppts or excepts?
The Dingo Pup is a good solution for the input module?
To i by the 3 amps pcb and the dINgO pcb,... or other pcb that you say it´s better.
Thanks, Luís
Postby Joe Malone » Fri Mar 09, 2012 7:12 am
slb1959 wrote:Hi,..
Aceppts or excepts?
Woops. Accepts Paypal
Yes a dingo pup would allow for balanced in to unbalanced out for volume control and then unbalanced output of volume control to balanced out to drive amps with gain if needed. So would be a good idea.
Are you only making a mono setup ? For stereo you will need double the PCB's
Thanks, Luís
8) :D
Users browsing this forum: Google [Bot] and 6 guests
