Page 15 of 15
Posted: Tue Oct 24, 2017 5:44 pm
kante1603 wrote:
G-Sun wrote:Hi!
My meter-light died.
How may I replace it?
Hello G-sun,
the squared and the round part can be detached.Take care when doing that,gently tear them apart.No brutal force please,or you might damage the meter or bend the needle.
Then gently tear apart the white inlay.
After that you can reach the led.Take care while unsoldering and soldering a new one in,also watch polarity.
Have attached a pic,hope that helps.
Best regards,
Thanks Udo
Do just as Udo said :-)
Posted: Wed Oct 25, 2017 5:05 pm
by G-Sun
kante1603 wrote:
G-Sun wrote:Hi!
Hello G-sun,
Thanks a lot Udo!
Tried to use my LA500 today, but turns out it's more than the light.
Seems like meter is moving correct GR/Level, but it's not compressing and the Gain-pot is not doing anything.
Any pointers to the cause of the problem?
Posted: Wed Oct 25, 2017 5:13 pm
G-Sun wrote:
kante1603 wrote:
G-Sun wrote:Hi!
Hello G-sun,
Thanks a lot Udo!
Email me some clear in focus photos of your build so I can check it over. And answer all of the below questions.
Does the meter light? If NO link over the outside 2 terminals on the meter with a piece of wire to bypass the led and check if the comp is now working except for light not going. (If the led is blown the comp will never come out of bypass mode otherwise.)
Does threshold turn the level down ? Does GR meter show reduction?
Does makeup turn the level up?
Posted: Fri Oct 27, 2017 11:57 pm
by G-Sun
Joe Malone wrote: Email me some clear in focus photos of your build so I can check it over. And answer all of the below questions.
The unit has worked perfect for some 3 years.
Please tell me if you need the pictures after reading this post.
There is no light.
No, there is no audio GR, but the meters show GR.
No
Your explanation that the unit does not come out of bypass-state, caused by the VU-led, makes very much sense.
Meters is showing GR, and VU-out is reacting to GR and MakupGain.
If you don't tell me other-wise, I'll just test with bypassing led, and then change led.
What's the specs for a replacement led?
Very helpful answer :)
Posted: Sat Oct 28, 2017 8:13 am
Yes first try a wire across the outside terminals of the meter to bypass the led and see if the comp works without led just to check all the wiring is ok.
Led is white clear 5mm about 800 to 1000mcd. We have the LED as spare part on our website if you are trying to match other LA500 meter lights exactly. Open the meter as Udo showed to check led hasn't broken off one of the mounting posts if comp has been working so long. If still soldered in place replace led. New led must go in same way around Anode & Cathode and face the top of the meter. In LA500 you can unclip back of meter without removing wires or meter from the metal frame.
Posted: Sun Oct 29, 2017 7:05 pm
by G-Sun
Joe Malone wrote: Yes first try a wire across the outside terminals of the meter to bypass the led and see if the comp works without led just to check all the wiring is ok.
Thanks a will!
Was hitting the replacement led in your shop until 20aud for shipping :)
I'll have a look another place
Posted: Tue Oct 31, 2017 7:22 pm
by G-Sun
Now, look here:
Seems like we've found the course.
Remember when soldering that this spot seemed a little weak :)
Fixed. Working perfect again. Thank you!
Posted: Tue Oct 31, 2017 10:22 pm
by kante1603
G-Sun wrote:Now, look here
Looks like an LA500A to me,not LA500.
Wrong thread......?
Posted: Thu Nov 02, 2017 1:45 pm
Cool great to hear it was a simple solder joint to fix :-)
This is a LA500A not LA500 so I will move it over to the LA500A build thread
Posted: Thu Sep 27, 2018 3:35 am
by studiomollan
If you were to try and fit an original T4B module in here, where would it go? I just replaced a drip t4b for a kenetek in a diy LA2a and it made such a huge difference. Im not saying the la500 sounds bat the way it is, i love mine, but would be fun to hear the difference.
Emil
Posted: Thu Sep 27, 2018 10:04 am
studiomollan wrote:Hi,
Emil
The LA500 cannot run a luminescent cell as they need 40vac to 200vac to light. So T4B will never work in LA500.
Posted: Fri Sep 28, 2018 12:00 am
by studiomollan
Ok. then i know. Thanks joe!
