Regurgitator kit Build Thread
Postby Joe Malone » Mon Mar 09, 2020 11:11 am
earthsled wrote:
Hi Joe - just wondering if this html sheet ever was finished/posted? I'm interested in calculating fixed resistances in place of the trim pot for various levels of gain on the Regurgitator. Perhaps you could share the formula? Thanks for your help!
I did get a fair way with this but haven't completed it. I will dig it out and try to get done finally.
MrMesh
Postby MrMesh » Mon Mar 09, 2020 5:25 pm
Hi there and thanks Joe/Rob for making this kit! I'm wondering if anyone can help answer a few questions that I have:
1. What is the recommended method of mounting the PCBs to an enclosure? I don't see any mounting holes and was wondering how most people were securing the PCBs - aside from the chassis mount screws of the XLR connectors - if at all.
2. In my efforts to find the right 5k 25-turn trim pot I've come across two separate trim pots that seem to be almost identical, yet the component cost differential is notably large: i. https://www.mouser.de/ProductDetail/652-3296W-1-502RLF and ii. https://www.mouser.de/ProductDetail/81-PV36W502C01B00 . Can anyone identify which of these I'd need for the build?
3. Is the rating of 21mA per card mentioned earlier in this thread accurate? I'm looking to install 10 units into an enclosure and wondering 250mA would cover my power needs.
Cheers!
Postby Joe Malone » Mon Mar 09, 2020 8:10 pm
MrMesh wrote:Hi there and thanks Joe/Rob for making this kit! I'm wondering if anyone can help answer a few questions that I have:
You can mount single pcb in heatshrink tube if cable in and out. Pair or more you can cut a V into the V groove :-) at each end of the pcb so a standoff and M3 bolt can be used. Or if using plastic clip on stand offs drill out unused corner +/-V power pads to 3mm to clip the stand off on to.
Both seem to fit and are the 5k value needed so both should work fine.
8pack regurg with 8 x NE5532A idle current @ +/-18v is roughly 80mA. So if you are only driving 10k loads then 150mA to 200mA is heaps.
Postby Joe Malone » Mon Mar 09, 2020 10:13 pm
Resistor values for 1dB gain steps from robs regurgitator calculator.
Gain - RGain = R11 + RV1
+18db - 50R
+17dB - 56R
+16dB - 63R
+15dB - 71R
+14dB - 81R
+13dB - 91R
+12dB - 103R
+11dB - 116R
+10dB - 131R
+9dB - 149R
+8dB - 169R
+7dB - 192R
+6dB - 219R
+5dB - 250R
+4dB - 286R
+3dB - 329R
+2dB - 378R
+1dB - 437R
0dB - 507R
-1dB - 593R
-2dB - 696R
-3dB - 1198R
-4dB - 1478R
-5dB - 1198R
-6dB - 1478R
-7dB - 1870R
-8dB - 2440R
-9dB - 3360R
-10dB - 5080R
-11dB - 9280R
-12dB - 35000R
MrMesh
Postby MrMesh » Mon Mar 16, 2020 8:52 am
Joe Malone wrote:8pack regurg with 8 x NE5532A idle current @ +/-18v is roughly 80mA. So if you are only driving 10k loads then 150mA to 200mA is heaps.
Thanks Joe!
I'll be driving the following loads:
IN: 1 x 6.6kΩ-47kΩ (selectable)
IN: 1 x 40kΩ
IN: 1 x 1MΩ
IN: 1 x 47kΩ
OUT: 2 x "more than 5kΩ"
OUT: 2 x 600Ω
OUT: 1 x 250kΩ (0.5-1.0V) or 500kΩ (10-50mV)
OUT: 1 x 100kΩ
Would the 150-200mA still suffice?
Postby Joe Malone » Mon Mar 16, 2020 10:51 am
Thanks Joe!
IN: 1 x 40kΩ
IN: 1 x 1MΩ
IN: 1 x 47kΩ
OUT: 2 x 600Ω
OUT: 1 x 100kΩ
If you are supplying +/-18v and no zeners then yes that will be fine.
Remember the input impedance of regurgitator is 15k balanced and 7k5 unbalanced so driving from a much higher output impedance device will drop lots of level.
MrMesh
Postby MrMesh » Wed Mar 18, 2020 8:34 am
Joe Malone wrote:Remember the input impedance of regurgitator is 15k balanced and 7k5 unbalanced so driving from a much higher output impedance device will drop lots of level.
Ok, and there'll still be significant loss of signal despite the +18dB gain? Also, is there any way to counter this level drop with this kit by changing any parts around, or is there a more suitable kit for dealing with the higher impedance outputs?
Postby Joe Malone » Wed Mar 18, 2020 10:13 am
Best to let me know exactly what you are driving into the regurgitator so I can see the problem clearly. Like impedance out and max unbalanced output level and max balanced level you want out?
For high input impedance like 100k input to balanced output. dingo pup kit or tardigrade kits. Input impedance of these kits can be higher like 1Meg but depends on the opamp type used.
MrMesh
Postby MrMesh » Wed Mar 18, 2020 6:37 pm
MrMesh wrote:Best to let me know exactly what you are driving into the regurgitator so I can see the problem clearly. Like impedance out and max unbalanced output level and max balanced level you want out?
Hey Joe, thanks again for your time. I'll either be patching from/to the balanced outs/ins of my Antelope Orion 32 interface or from/to the balanced Aux Sends/Echo Returns of my Trident 65 console into one of 4 effects units. The 4 units in question all feature unbalanced connectivity, and are:
i. Roland SRE-555 - Chorus Space Echo: 1 x input, 6.6-47kΩ (switchable in 3 stages). 2 x outputs, 'more than 5kΩ'
ii. A/DA STD-1 - Stereo Tapped Delay: 1 x input, either 40kΩ or 1MΩ FET input (switchable). 2 x 'single-ended, 1/4 phone jacks, drives 600 ohm'.
iii. Dynacord S65 - Tube Tape Delay: 1 x input, 17 mV / 1MΩ. 1 x output, choice of either '0.5-1.0V / 250kΩ' or '10-50mV / 500kΩ'
iv. Telefunken Echomixer - 3-ch mixer w/Spring Reverb: 1 x input, choice of either '≤ 3mv / 2.5kΩ', '80mV / 47kΩ' or '500mV / 270kΩ'. 1 x output, 100mV / 100kΩ.
Postby Joe Malone » Sat Mar 21, 2020 9:46 am
OK these are exactly what our dingo pup kit was made for with its balanced in to unbalanced and unbalanced to balanced amp on one pcb. With Fet input opamp you can set the input impedance by one resistor to 1Meg or More. This can also be done in compact form with our Tardigrade unbalanced to balanced kit for 8 channels to DB25 and the new palpigrade 8 channel Db25 kit will do the balanced to unbalanced part when it is available in about 1 to 2 weeks.
MrMesh
Postby MrMesh » Mon Mar 23, 2020 6:51 am
Joe Malone wrote:OK these are exactly what our dingo pup kit was made for with its balanced in to unbalanced and unbalanced to balanced amp on one pcb. With Fet input opamp you can set the input impedance by one resistor to 1Meg or More. This can also be done in compact form with our Tardigrade unbalanced to balanced kit for 8 channels to DB25 and the new palpigrade 8 channel Db25 kit will do the balanced to unbalanced part when it is available in about 1 to 2 weeks.
Thanks Joe! I'll grab a Palpigrade/Tardigrade combo with a couple of Dingo Pups in that case. Do you foresee that the Coronavirus situation will delay the release of the Palpigrade?
Postby Joe Malone » Mon Mar 23, 2020 12:07 pm
Should be ready to ship mid next week.
Main delay here at the moment is just lots of orders as everyone seems to want to build something while having to stay at home.
