Page 2 of 5
Posted: Tue Jul 20, 2010 5:44 pm
by Holger
It's available in the shop now.
Re: New 40 Led PPM/VU/GR Meter kit with Peak hold
Posted: Tue Jul 20, 2010 8:05 pm
Yes VUPPMGR40 is now on the web shop
Added to first post of this thread
Ver 1.0 info and Youtube Stereo demo of features.
Direct Link to VUPPMGR40 kit on JLM web shop
Posted: Sat Aug 07, 2010 12:38 pm
by heath
Hmmm - would these fit in a 500-series faceplate? If so, I'm picturing a 'Master' module for a 500-series rack: 2 units wide (for stereo I/O), stereo meters, output attenuation knob (to feed your monitors), and a couple of the meter switching features. Hey, while I'm dreaming, maybe add a mono switch, L+R/L-R switch, and a headphone amp!
Posted: Mon Aug 09, 2010 7:09 pm
heath wrote:Hmmm - would these fit in a 500-series faceplate?
Yes they are made to fit in 500 module size easy and run on +/-16v from the 500 rack.
The Master module is along the lines of what I was thinking exactly. Also single 500 module with the meter and 100mm fader could work as well.
I am working on a 2mm dark smoked perplex front for a small Hammond 2 piece plastic case. To give a good looking professional stereo meter pair for not many $$.
Also a bevel edge version for fitting to the front of rack cases to give a professional look to these meters.
Holger may also want to share his 500 module ideas he has shown me.
Posted: Tue Aug 10, 2010 1:35 am
by Holger
Joe Malone wrote:Holger may also want to share his 500 module ideas he has shown me.
I will, but still waiting for the first panel. I'd like to show pictures rather than drawings.
Posted: Thu Aug 12, 2010 11:27 pm
by heath
Joe Malone wrote:I am working on a 2mm dark smoked perplex front for a small Hammond 2 piece plastic case. To give a good looking professional stereo meter pair for not many $$.
That sounds pretty cool too! I'd like a single 500-series meter maybe in future, as I do most of my tracking and mixing in mono/single tracks, but a small-box pair of meters could fit just about anywhere in my studio. Look forward to seeing some examples when they're ready.
heath.
Posted: Fri Aug 13, 2010 2:04 am
by Holger
Here is my API 500-compatible version:
Metal work (sunny afternoon with my Dremel):
I used the L-bracket and the little connector PCB from the 51X Audio guys.
You can get them here:
http://www.classicapi.com/catalog/
The switches:
PEAK HOLD: the highest value stays forever, switching it off resets the peak value and returns to normal behavior (highest value stays for some seconds).
FAST: lifts off a 1 µF cap.
There are three 1 µF caps named C6 a-c. These caps are responsible for the meter fall back timing. I decided to use C6a permanently, FAST lifts C6b for a slightly faster
fall back timing. So C6c is not used in my meter.
I recommend to solder C12 and C13 staggered because there is not so much space between the PIC and the TL 074. You can also solder the two caps after inserting the two ICs.
Posted: Sat Aug 21, 2010 9:13 am
Holger wrote:Here is my API 500-compatible version:
The switches:
Looks great Holger.
I have been thinking I should drop the VUPPMGR40 PCB onto a 500 PCB so a mono or stereo with a 500 version and normal PCB version stacked can be done with no wiring.
To get stereo in could use the input XLR unbalanced or the output XLR as the right in for balanced inputs.
Posted: Mon Sep 20, 2010 5:38 am
by briomusic
hi joe,
I can't figure out if there is a way to control the brightness of the LEDs...is there a schematic available for this kit?
cheers
brio
Posted: Tue Sep 21, 2010 10:07 pm
briomusic wrote:hi joe,
cheers
brio
Changing the 10 x 100R to larger values like 220R will take the brightness down and allow 2 kits to use one 24vdc to 5vdc SMPS.
The whole kit can be built and running while testing a couple of different value resistors in the resistor positions without soldering them in to work out what brightness you want.
I can email the schematic to you if you send me an email.
Posted: Sun Oct 03, 2010 3:45 pm
I had a couple of emails asking how I connected a pair of VUPPMGR40 together and was still able to use the jumpers on the top module.
The 10 pin IDC headers on several VUPPMGR can just be connected together with a ribbon cable or as the photo's show below.
A section of 2 row IDC plug or the main part of a 10pin IDC cable plug modified can be soldered direct under the PCB.
Posted: Tue Feb 08, 2011 4:29 pm
by sleeper
Hi Joe, THis looks great, I'll be getting 2 soon, just have to sell some bits on Ebay first :roll:
You mentioned a perspex front panel for putting these neatly into a rack panel.
Did you make this? I'm going to be mounting 2 horizontally in a 1 space rack.
THought I'd ask.
Sleeper
Re: VUPPMGR40 kit (40 Led PPM/VU/GR Meter kit) BUILD THREAD
Posted: Sun May 22, 2011 7:29 pm
Add below info to the first post on this thread.
Only component changes that need to be done depending on power supply voltages are listed in the table below.
R13 & R14 changes are to give more headroom the the TL074 when running them at +/-12v (so when either ZD1 & ZD2 are 12v zeners or when running +/-12v into VUPPM terminals). It was found that the top 4 leds sometimes will not track as they should due to the TL074 approaching clipping at about +/-10.5vac. For all new builds I recommend fitting for any power rail voltages R13 = 150k and R14 = 75k which are now supplied in the kit. And all existing builds on +/12v add a second 200k resistor under the PCB across R13 to make R13 = 100k and a second 100k resistor under the PCB across R14 to make R14 = 50k. After changes to R13 & R14 the VU balance trim pot will have to be readjust upwards to match the PPM level with a 1k tone.
Note 1 The VUPPM can be made to run on 12v only with changes shown and a 1N4007 diode instead of 5v smps. Diode is mounted between 5v smps pin 1 Anode to pin 4 Cathode to supply 5v to PIC. The 1uF caps next to the smps may need to be changed to 100uF 25v electros if the 12v is coming form a noisy power source like a car.
See scale examples below
Rack version below
Posted: Thu Jun 02, 2011 11:49 pm
by Holger
Joe, for those who alredy built their meters, can you indicate the position of the relevant components on a photo?
Posted: Sat Jun 04, 2011 12:22 pm
Holger wrote:Joe, for those who alredy built their meters, can you indicate the position of the relevant components on a photo?
Great idea :D
Added to first post on this thread
Virtual PCB shots with R13 and R14 postions top and bottom of PCB.
More building info.
Sample Scale Photos.
