The simplest kit to build we have ever made.
This kit used with our prebuilt 48v 380mA SMPS power supply can make a 24v rail and 48v rail to run 2 x neve 1272 / 1290 / 1073 modules or V672 Telefunken modules with phantom power. Making the simplest power supply with no power supply related hum problems. It also can run on any voltage in the world (90vac to 240vac).
Simple Zener Regulator kit Now Available
Now Available on website here http://www.jlmaudio.com/JLM%20Power%20Supply.htm
Do not bolt the transistor metal tab straight to the metal case it is sitting at 48v potential. The Simple Zener kit comes with a insulation kit so it can be bolted to the metal case or heatsink without the transistor metal tab actually shorting to the case or heatsink.
More info on how to use the grey silicon insulator and white bush go to the Power supply assembly instructions at the bottom of the page at the link below.
