Power rail splitter which makes a virtual centre ground out of one a single floating power rail.
Used with our 48v SMPS power supply it will turn the 48v floating rail into +/-24v with a centre 0v ground to run bipolar rail devices.
Power Rail Splitter
Online
Power Rail Splitter
Re: Power Rail Splitter
Am I right in thinking that you would still need to bias the opamp non-feedback input with the 1/2v "ground" from this supply (which would be 24V compared to the power supply ground)?
Online
We can supply them for $35AUD if you need one.
We have been using the rail splitter for a while now in several of our custom racking jobs to run dingo kits etc with our 48v smps but depending on what power source and what gear is hanging off of it you need to have the test equipment to determine it is working right in each situation which is why I haven't put it up as a kit as it would just increase my email.Hi Joe, is the Power Rail Splitter shipping?
The power supply used to run into the Rail Splitter must be fully floating with no DC ground reference as the rail splitter will make a virtual ground at half the rail which can be connected to mains ground.Joe
Joe - thinking this is exactly what I have been looking for and would rather build it on your board than perf. Am assuming I could set it up for +16-16 instead of 24 with different regulators?
Also assuming I can use it with this - 48v 15w 315mA SMPS to have all internal power supply?
Just needing to power a self contained API325 DI only type box.
