Page 23 of 23
Posted: Thu Sep 05, 2019 2:23 am
by ylinjohto
[/quote]
Check the BA is fully working with NE5532A and input reg voltage is set to +30 to +36vdc on +V of the opamp sockets. If so you should be able to remove the NE5532A and fit 6 sockets and plug in the discrete opamp. Remember the discrete opamp is only driving the +out so link on dip socket is needed to put -out to 0v so quasi balanced out works.[/quote]
Opamp voltage is 24,1 and I guess that is ok because the Soun Skulptor sk99 is 24v op amp. I just need to clarify what exactly needs to be connected? 0V opamp socket to -output of the line output? Did I understood this correctly?
Posted: Thu Sep 05, 2019 10:50 am
Thanks![/quote]
If sk99 is +/-24v you want the reg linked over so you have +48v on +V pin as the BA uses this 48v as +/-24v but 0v is referenced to -24v.
Posted: Wed Sep 18, 2019 6:33 pm
by ylinjohto
Hi, Thank you for information!
I was wondering what is the output impedance of the unit. With JLM14 input tranfo and NE5532A op amp. Does DOA change output impedance?
Posted: Wed Sep 18, 2019 8:57 pm
ylinjohto wrote:Hi, Thank you for information!
Balanced output impedance with NE5532A or discrete opamp no output transformer using +out and -out is 102ohm if using 51R or 66ohm if using 33R.
Posted: Mon Jun 08, 2020 3:00 pm
by Vernois76
Hey Joe, just got my BA kits in today. Just a quick question; on this version 2 you’ve added a trim adjustment for the opamp. Is there a setup necessary for standard 48v supply and 24v opamp?
Thanks for your time!
Gavin
Posted: Mon Jun 08, 2020 8:27 pm
Gavin
HI Gavin
For +/-24v opamps you can leave off the BD681 and still link E - C or just wind the trimpot to full. Either works fine. See the Ver 2 schematic under the photo of the new balck Ver 2 pcb for detail.
