JLM Phantom Powered Active DI
conleycd
Re:
Post by conleycd »
Joe Malone wrote:DI's usually just have the 2 jacks wired to each other for plugging into and out of the DI as a loop. You can do this by just wiring the second jack across the DI jack. Or if you want a driven output to isolate the load connect the output jack to the +out on the DI PCB with a 1k resistor.
If I want 2 buffered outputs plus a tranformer output - should I run all 3 outputs through 1k resistors from the output?
CC
