The AC volts should be taken as the highest DC voltage you can set on the output of a reg. So no dc rails above 15v unless you are using the 48v rail as the pump charge will give you 30v but only at about 100mA max.alistair wrote:Thanks for your reply Joe.
Yes, I used your calculator to VA needs. I'm using a 15v 50VA transformer, as your calculator suggested I needed 41VA when I entered very overspec'd values. I'm getting a voltage dip even if I just plug in one 50mA draw pedal, but I used values of 600 and 700mA for the 12v and 9v taps, and 400ma for the 24v.
Ok this sounds like you problem. The 15vac should be wired between 0v and one AC in unless you have done the neve mod shorting the negative rail. Wiring to both AC in with no 0v will not work and the power supply will drift all over the place as 0v has no reference so hence the regs have no reference. Nothing should reg and the power supply should not be wired this way. Wire the 15vac between 0v and one AC in and you will be able to regulate finally.I've done as you suggested and checked values at the AC points on the board, and also the caps 1000uF caps. The voltage is sagging at the AC points if I plug in a single pedal- from 16.42v to 16.28v when drawing about 300mA of current, and from 16.42v to 16.39v when about 50mA is drawn. I'm not sure if this is within reasonable amounts of if it should remain steady regardless.
If you have 2 x 15vac wire them in series to make 30vac centre tap and put the centre tap to 0v and each each end of the 15vac winding to a AC in each. You should be able to measure 30vac between AC in then. the centre 2 wire colours in the diagram on thew side of the transformer go to 0v.
