Adding insert path to BA?
tenchijin2
Post by tenchijin2 »
How hard would it be to include an insert path (1/4" TRS) to a baby animal? I'm thinking I'll eventually want to track with some outboard compressors.
Re: Adding insert path to BA?
The BA pcb is a one stage mic pre so there is no where to insert except after it. The BAD PCB can have a insert added into the wire going from the O to the output level pot easily as it is a 2 stage mic pre.
tenchijin2
I see. I suppose it really won't matter since I'll be using a A/D converter. I can go mic->ba->compressor->A/D converter, right?
Aric
Yes that is correct
